Topic "Include filter does not work recoursively"
maxx_981
Hy there,
I try to upload any file ending with index.html or index.php. Therefore a create an Include filter like this:
*/*index.php, */*index.html
I also tried *index.php any many other syntaxes, but I can't get it to work right. I will just stop after a very short time of synchronization and say, No Differences Found.
But it didn't actually look recoursively through the folders.
So, is my Syntax not correct, or is my task not doable with WinSCP?
Thank you,
maxx
I missed some Data about me:
- Using Win7 on a 64-Bit system
- Using latest WinSCP
- Using SFTP
Thank you,
maxx
You need to add mask that matches all directories. Please read documentation:
http://winscp.net/eng/docs/file_mask#directory_mask
Thank you for the hint. I missed that part in the docs.
Cheers,
maxx
