Invalid access to memory - TTerminal::GetIsCapable
Goto page
Previous, 1, 2, 3, 4, 5, 6, 7, Next
test@...
WinSCP 5.7.7
Invalid access to memory.
(007100E0) TTerminal::GetIsCapable
(0007C53F) ntdll.dll
(00069D7A) ntdll.dll.KiUserExceptionDispatcher
(003826CC) System::Actions::TContainedActionList::UpdateAction
(0016A1C2) Vcl::Actnlist::TCustomAction::Update
(001DC02A) Vcl::Forms::_16777
(001DC0A8) Vcl::Forms::TCustomForm::UpdateActions
test@...
WinSCP 5.7.7
jordi@...
WinSCP 5.7.7
(000461A6) ntdll.dll.RtlRaiseStatus
(00046032) ntdll.dll.KiUserExceptionDispatcher
fabianchesta@...
WinSCP 5.7.6
(0070F590)
(003823D8)
(00169ECE)
(001DBD36)
(001DBDB4)
1029866394@...
无效的内存访问。 - TTerminal::GetIsCapable
WinSCP 5.7.5
无效的内存访问。
(0070E9A4) TTerminal::GetIsCapable
(0008A61F) ntdll.dll
(0038239C) System::Actions::TContainedActionList::UpdateAction
(00169EB2) Vcl::Actnlist::TCustomAction::Update
(001DBD1A) Vcl::Forms::_16777
(001DBD98) Vcl::Forms::TCustomForm::UpdateActions
Re: 无效的内存访问。 - TTerminal::GetIsCapable
fabianchesta@...
1) Sorry for my english.
2) I put WinSCP.ini in a different folder
3) this folder is syncronize using Google Drive. I use two diferent PCs and this way when I made a modification its replicate in the other PC
4) Eventualy when Google Drive syncs the changes, WinSCP try too acces the file and "Invalid access to memory" error appears.
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
abc@...
WinSCP 5.7.6
(0070F590) TTerminal::GetIsCapable
(00062496) ntdll.dll
(003823D8) System::Actions::TContainedActionList::UpdateAction
(00169ECE) Vcl::Actnlist::TCustomAction::Update
(001DBD36) Vcl::Forms::_16777
(001DBDB4) Vcl::Forms::TCustomForm::UpdateActions
Re: Invalid access to memory - TTerminal::GetIsCapable
artur.borecki@...
WinSCP 5.7.6
(000623AA) ntdll.dll
gail.buffington@...
WinSCP 5.7.5
(0005A5DA) ntdll.dll
andreas@...
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
efektsoffi@...
Ошибка доступа к памяти - TTerminal::GetIsCapable
WinSCP 5.7.7
Ошибка доступа к памяти.
Трассировка стека:
(007100E0)
(000A284F) ntdll.dll
(0009035A) ntdll.dll.KiUserExceptionDispatcher
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
eehosseini@...
WinSCP 5.7.7
dylans@...
WinSCP 5.7.6
(0070F590)
(003823D8)
(00169ECE)
(001DBD36)
(001DBDB4)
mikael.r@...
Accès mémoire invalide - TTerminal::GetIsCapable
WinSCP 5.7.7
Accès mémoire invalide.
Trace de la pile :
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
Re: Accès mémoire invalide - TTerminal::GetIsCapable
b.hogeman@...
WinSCP 5.7.7
(007100E0)
(0008A63F) ntdll.dll
(00077E9A) ntdll.dll.KiUserExceptionDispatcher
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
anthony.lomangino@...
WinSCP 5.7.6
daniel@...
WinSCP 5.7.7
javiereduardo@...
WinSCP 5.7.7
jyotsna.jaisankar@...
WinSCP 5.7.6
sql2008a@...
WinSCP 5.7.6
(000689FA)ntdll.dll
(00068E5E)ntdll.dll
(0006B2C9)ntdll.dll
(0006B547)ntdll.dll
jbender@...
<App timed out, I believe I closed that window that has you log back in. I had timed out once previously and had to reconnect.>
WinSCP 5.7.7
anilgoud0203@...
WinSCP 5.7.6
robinwe@...
WinSCP 5.7.7
abhishek6490@...
WinSCP 5.7.6
(000455C6) ntdll.dll.RtlRaiseStatus
(00045452) ntdll.dll.KiUserExceptionDispatcher
contact@...
WinSCP 5.7.6
solomon.sims@...
I am not sure what caused the error. The only thing I know existed was a prolonged disconnect to the network via LAN or VPN.
WinSCP 5.7.6
andreas@...
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
NOBODY@...
On a Upgraded from Windows 7 to Windows 10 OS:
WinSCP 5.7.7
(007100E0)
(0009034A) ntdll.dll.KiUserExceptionDispatcher
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
NOBODY@...
Everytime when I want to close connection or close the program.
On WIndows 10 Pro with last updates.
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
dseaman@...
WinSCP 5.7.7
10@...
WinSCP 5.7.6
Трассировка стека:
(0070F590)
(00046186) ntdll.dll.RtlRaiseStatus
(00046012) ntdll.dll.KiUserExceptionDispatcher
(003823D8)
(00169ECE)
(001DBD36)
(001DBDB4)
rick@...
I keep my configurations in a .ini file that's stored on a local folder managed by Google Drive. Here's the command line from the Windows 7 Professional shortcut I use to open WinSCP.
"C:\Program Files (x86)\WinSCP\WinSCP.exe" /INI="C:\Data\Google Drive\Work\WinSCP\WinSCP.ini"
If I perform multiple operations which change my .ini file in close succession, I'll sometimes get a "file is busy" message of some sort. (Sorry don't have exact text - can't make it happen right now.)
If I don't wait long enough (presumably to let Google Drive finish syncing the modified .ini file) I get a popup containing the stack dump below. I cannot successfully dismiss this popup - it immediately comes back if I do - and I have to kill the WinSCP.exe process.
If I am not running the Google Drive application, I never have this issue.
I don't remember ever seeing this error before I upgraded to this version of WinSCP.
WinSCP 5.7.6
(0005A466) ntdll.dll
dhruv.vd@...
WinSCP 5.7.7
(007100E0)
(00045CC6) ntdll.dll.RtlRaiseStatus
(00045B52) ntdll.dll.KiUserExceptionDispatcher
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
Rick
Just downloaded and installed the debug version. Will use this one for now.
Happened again today before getting debug version. Uploading some screen captures.
Thanks!
Rick
Description: First error message that appears, which can be dismissed, along with the un-dismissable stack trace.
bshogeman@...
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
bshogeman@...
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
bshogeman@... wrote:
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
mikael.r@...
WinSCP 5.7.7
Trace de la pile :
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
meu@...
WinSCP 5.7.6
mikael.r@... wrote:
WinSCP 5.7.7
Trace de la pile :
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
alkuehne@...
I try to rename a file adding a "_" character after it and then try to drag and drop a new version of the originally named file from my folder into the AFS space.
WinSCP 5.7.6
erickizc@...
Acceso a memoria no válido - TTerminal::GetIsCapable
WinSCP 5.7.7
Traza de la pila:
WinSCP 5.7.6
csroder@...
This disconnects frequently from my SFTP server. I am constantly getting a prompt to log back in, and failed connections. This is the first time I have seen this error message. I was clicking cancel to get the logon prompt to go away because I was finished with it for the day.
WinSCP 5.7.7
tapan.kumarsahu@...
WinSCP 5.7.7
(007100E0)
(00060DE2)ntdll.dll
(000613E0)ntdll.dll
(0006332A)ntdll.dll
(0006351F)ntdll.dll
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
wuhaifengdhu@...
WinSCP 5.7.7
gabor.naszvadi@...
Érvénytelen memóriaelérés - TTerminal::GetIsCapable
WinSCP 5.7.7
Veremkivonat:
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
shinobim@...
WinSCP 5.7.5
(0070E9A4)
(0038239C)
(00169EB2)
(001DBD1A)
(001DBD98)
johannes.roth@...
Zugriffsverletzung - ungültiger Zugriff auf den Speicher - TTerminal::GetIsCapable
This happens if you store your WinSCP portable in a Cloud-Drive like "Google Drive" to sync it between Computers.
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
Re: Érvénytelen memóriaelérés - TTerminal::GetIsCapable
richkips2006@...
WinSCP 5.7.7
andreas.witte@...
SSH over Openvpn, openvpn connection broke while I was in weekend, returned from weekend, saw this error. if I click ok, it comes back.
WinSCP 5.7.7
manhhailua@...
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
rommel.loayza@...
WinSCP 5.7.7
cablay28@...
WinSCP 5.7.6
(0070F590)
(003823D8)
(00169ECE)
(001DBD36)
(001DBDB4)
manhhailua@...
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
rommel.loayza@... wrote:
WinSCP 5.7.7
whyshoulditell@...
WinSCP 5.7.4
(0070E490)
(0005A7EA) ntdll.dll
(0038210C)
(00169C22)
(001DBA8A)
(001DBB08)
manhhailua@...
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
kalin.kalchev@...
WinSCP 5.7.7
daniel.pommert@...
WinSCP 5.7.7
linda.howard@...
<I receive a memory is full, can not create use FTP - something like that>
WinSCP 5.7.6
patricia.k.flickner1@...
WinSCP 5.7.7
(007100E0)
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
ecoulon@...
WinSCP 5.7.5
cmason@...
WinSCP 5.7.5
(00045A86) ntdll.dll
glen.xin.guo@...
WinSCP 5.7.1
[0175D820] TTerminal::GetIsCapable
[7727F08E] ntdll.dll
[7727EEF6] ntdll.dll.KiUserExceptionDispatcher
[013D2888] System::Actions::TContainedActionList::UpdateAction
[011BA39E] Vcl::Actnlist::TCustomAction::Update
[0122C206] Vcl::Forms::_16777
[0122C284] Vcl::Forms::TCustomForm::UpdateActions
andreas@...
WinSCP 5.7.7
(007100E0)
(0008137F) ntdll.dll
(0006EF1A) ntdll.dll.KiUserExceptionDispatcher
(003826CC)
(0016A1C2)
(001DC02A)
(001DC0A8)
testdeveloper30@...
WinSCP 5.7.6
ing.johnnymartinezgmail.c
WinSCP 5.9.1
Traza de la pila:
(0076FB88) TTerminal::GetIsCapable
(00037771) TNonVisualDataModule::ExplorerActionsExecute
(003B4AAC) System::Actions::TContainedActionList::ExecuteAction
(0019BCB1) Vcl::Actnlist::TCustomAction::Execute
(004522C2) Tb2item::TTBPopupMenu::IsShortCut
prabhu.srikanth@...
WinSCP 5.7.7
anitha1313@...
WinSCP 5.7.7
lalji@...
WinSCP 5.7.7
(00066086)ntdll.dll
(00066481)ntdll.dll
(0006873D)ntdll.dll
(000689B7)ntdll.dll
(001DC0A8) Vcl::Forms::TCustomForm::UpdateActions :x :x
10@...
WinSCP 5.7.6
Трассировка стека:
(0070F590)
(003823D8)
(00169ECE)
(001DBD36)
(001DBDB4)
albertorubio.t@...
WinSCP 5.7.7
Traza de la pila:
noemail@...
It happen when I rebooted the Linux server on which WinSCP was connected.
Anyway another issue is the timeout when the connection is down between winscp and a server, and also cancel never works. Please update this part of the program.
WinSCP 5.7.6
Re: Ошибка доступа к памяти - TTerminal::GetIsCapable
10@... wrote:
WinSCP 5.7.6
Трассировка стека:
(0070F590)
(003823D8)
(00169ECE)
(001DBD36)
(001DBDB4)
fxdtim@...
Sitting in folder C;\user\downloads, in left pane
double-dot folder is highlighted
New / Directory or F7 creates error.
Any folder or file can be highlighted and the error is generated when attempting to create a new directory.
Windows 10 Pro 32-bit
WinSCP 5.11.1
(00799F30) TTerminal::GetIsCapable
(000A512F) ntdll.dll
(00093261) ntdll.dll.KiUserExceptionDispatcher
(0003811C) TNonVisualDataModule::ExplorerActionsExecute
(003BDCD8) System::Actions::TContainedActionList::ExecuteAction
(001A4E11) Vcl::Actnlist::TCustomAction::Execute
(0037BB94) System::Classes::_18201
(000356E5) USER32.dll
(0001971D) USER32.dll
(00019212) USER32.dll
(0001906B) USER32.dll.DispatchMessageW[img][/img]
https://winscp.net/tracker/1558
f.hadizadeh@...
WinSCP 5.12
(007B42FA) TTerminal::GetIsCapable
(0006248E) ntdll.dll
(003BFE30) System::Actions::TContainedActionList::UpdateAction
(001A5D96) Vcl::Actnlist::TCustomAction::Update
(00217BFE) Vcl::Forms::_16777
(00217C7C) Vcl::Forms::TCustomForm::UpdateActions
f.hadizadeh@...
WinSCP 5.12
sllang@...
WinSCP 5.12
(00081D3F) ntdll.dll
patrick.berthelot@...
WinSCP 5.12
Trace de la pile :
jimmi.prajapati@...
WinSCP 5.12.1
(007B4FB6) TTerminal::GetIsCapable
(00088D5F) ntdll.dll
(0006FC11) ntdll.dll.KiUserExceptionDispatcher
(003C0394) System::Actions::TContainedActionList::UpdateAction
(001A62FA) Vcl::Actnlist::TCustomAction::Update
(00218162) Vcl::Forms::_16777
(002181E0) Vcl::Forms::TCustomForm::UpdateActions
perssongunnar@...
WinSCP 5.12.1
(0008591F) ntdll.dll
(0006EAC1) ntdll.dll.KiUserExceptionDispatcher
vishakha@...
WinSCP 5.12.1
hellstern.cyril@...
WinSCP 5.12.2
Trace de la pile :
(007B64C6) TTerminal::GetIsCapable
(003C0F00) System::Actions::TContainedActionList::UpdateAction
(001A6C96) Vcl::Actnlist::TCustomAction::Update
(00218AFE) Vcl::Forms::_16777
(00218B7C) Vcl::Forms::TCustomForm::UpdateActions
melinda.vaughn@...
WinSCP 5.13
(007B65C6) TTerminal::GetIsCapable
(00081D0F) ntdll.dll
(003C0F10) System::Actions::TContainedActionList::UpdateAction
(001A6CA6) Vcl::Actnlist::TCustomAction::Update
(00218B0E) Vcl::Forms::_16777
(00218B8C) Vcl::Forms::TCustomForm::UpdateActions
melinda.vaughn@...
WinSCP 5.13
melinda.vaughn@...
WinSCP 5.13
melinda.vaughn@...
WinSCP 5.13
melinda.vaughn@...
WinSCP 5.13
mtaylor@...
Sitting idle for a period of time occasionally occurs, seems to be locking a lopp as cant close the popup - instantly reappears. need to use task mgr to close it.
WinSCP 5.13
Goto page
