Compare and sync the files into another local folder
zenpie9
Hi, I'm trying to implement a script which will compare all files in a local folder to that of the remote folder. But sync those files into another folder in local machine but not to the source local folder. Any suggestion/help really helps me. Thank you!
Re: Compare and sync the files into another local folder
So why don't you sync the remote files against the "another local folder"?
Zenpie9
Thanks for your prompt reply. Our scenario is, the remote files should be downloaded into folderA. And then they will be processed and sent to FolderB. But in some exception cases all files may not be downloaded into folderA. That's why to confirm all files were downloaded into folderA without fail, we need to verify all files at remote location were downloaded into folderB ultimately.
That's why, we need to verify all remote files against files in folderB and then download only missing files into folderA at the end of the day.
I hope I'm clear. If not plz tell me. Thank you for your time & efforts.
