permissions issue uploading to remote directory
revelstone77
I've been using WinSCP to maintain my HomeAssistant environment on a Raspberry Pi. All of a sudden when i try to upload a file from Local to Remote it fails with permission denied issue. If i go directly on to the Pi and edit the file there all is good. Any ideas?
Re: permissions issue uploading to remote directory
did as you asked and have attached the file (hopefully)
I do not see any "permissions denied" errors in the log.
Actually, I can see no errors at all.
