Filesize does not match
I am trying to automate a SFTPfile transfer using WinSCP. I created a script, but when it runs the file sizes do not match. Please refer to the attached document.
Please let me know what I am doing wrong.
Thank you,
Brady
I do not see any problem in the log.
Can you upload the file correctly using any other (even GUI) SFTP client?
ls
command to the script after the upload.
Can you attach log files on level "Debug 1" for comparable attempts, one working and one failing?
First, please add als
1) It'sIn regards to my batch file I want to add the Debug level 1 and 1s command. I am not familiar/the best with winscp. Can you look at my bat file let me know what I am doing wrong when trying to add these?
ls
, not 1s
/loglevel
, nor 1s
(sic).
1) It'sIn regards to my batch file I want to add the Debug level 1 and 1s command. I am not familiar/the best with winscp. Can you look at my bat file let me know what I am doing wrong when trying to add these?ls
, not1s
2) The log file does not look like the session was started using that batch file anyway. There's no/loglevel
, nor1s
(sic).
