Script not running
Working option using Profile1 - eteach_uk_limited@jobvacancies.ftp.businesslink.gov.uk
NOT Working option using Profile 2 - sftp://eteach_uk_limited@findajob.dwp.gov.uk
When I open WinSCP, I can login using either profile, but when I try running WinSCP using WinSCP.exe /command /script=jcp-ftp.txt only the first profile works.
Profile1
First profile working in script: https://ibb.co/fdBTvc7
First profile working using Login: https://ibb.co/ngy3DjB
Profile2
Second profile not working in script: https://ibb.co/Y0qr7nF
Second profile working using Login: https://ibb.co/P48HvzZ
Any suggestions as to what I might be missing?
# Automatically abort script on errors option batch abort # Disable overwrite confirmations that conflict with the previous option confirm off # Connect using a password open sftp://eteach_uk_limited@jobvacancies.ftp.businesslink.gov.uk
# Automatically abort script on errors option batch abort # Disable overwrite confirmations that conflict with the previous option confirm off # Connect using a password open sftp://eteach_uk_limited@findajob.dwp.gov.uk
Profile1
Profile2
