Can WinSCP check for password expiry using fine-grained password policy?
zhaodn
We encountered a incident where user could not be authenticated via WinSCP due to password expiry of 90 days in default domain policy, although password expiry was set to 365 days in fine-grained password policy.
Please advise if WinSCP can check for password expiry using fine-grained password policy.
Thanks in advance.
Re: Can WinSCP check for password expiry using fine-grained password policy?
No idea what that is. Can you share some reference? And a verbose session log file?
zhaodn
Hi Martin,
Below are some references I found for fine-grained password policy.
Basically there are 2 ways to set password expiry, GPO-based or fine-grained policies:
https://blogs.manageengine.com/corporate/general/2017/01/13/microsoft-password-policies-gpo-based-vs-fine-grained-policies.html
The way to set password expiry using fine-grained policies:
https://blogs.technet.microsoft.com/canitpro/2013/05/29/step-by-step-enabling-and-using-fine-grained-password-policies-in-ad/
Fine-grained password policies works but it seems not all applications can derive the fine-grained password expiry from the resultant set of policy, e.g. Windows "net user" command still shows the GPO-based expiry.
https://social.technet.microsoft.com/Forums/ie/en-US/5a2dd69c-40ad-4065-88ed-1b0a7bdf4414/fine-grain-policy-no-expiration-password-policy-question?forum=winserverGP
So we would like to confirm if WinSCP also derive the password expiry from GPO, if not what is the setting to let WinSCP check for password expiry using fine-grained password policy.
Hope my explanation of the problem is clear. Thanks.
Thanks for the links. Can you post the log file too?
zhaodn
Sorry Martin, I only have a screenshot of the error encountered. We are using public key but WinSCP still checks for password expiry of the account, which is another thing that puzzled us at that time. Issue resolved after we reset password for the account.
Hope you can explain how authentication works for WinSCP, does it check password expiry even if we are using public key and does it checks only GPO based password expiry?[/img]
  • password expired.jpg (106.93 KB, Private file)
WinSCP does not check any password expiry at all! That error message comes from your server.
You haven't told us even what protocol are you using, so I'm even not sure what authentication are you referring to.
Also that message looks like it comes from an SSH server, so it actually looks like WinSCP managed to get through a proxy. That's all too confusing.
Please get us a log file!
zhaodn
Hi Martin,
We are using SFTP protocol to connect to a Tectia SSH Server. Since the message comes from the server, I should probably raise my question to Tectia instead. Thanks for your help!
