Last modfied file time does not get.
sage12
Vietnam
I am writing a SFTP service. I browse the server directory and receive file structure in a log file, using ls command, to extract last modified file date time. When I look into log file, only receive last modified date. I do not receive any last modified file time.
Can you please tell me why I do not get file modified time????
Here is my log file
<session xmlns="https://winscp.net/schema/session/1.0" name="Ahsan@127.0.0.1" start="2011-03-17T14:28:59.076Z">
<ls>
<destination value="/" />
<files>
<file>
<filename value=".." />
<type value="D" />
<modification value="1899-12-30T00:00:00.000Z" />
<permissions value="---------" />
</file>
<file>
<filename value="fwis.xml" />
<type value="-" />
<size value="49152" />
<modification value="2011-02-08T00:00:00.000Z" />
<permissions value="r--r--r--" />
</file>
</files>
<result success="true" />
</ls>
</session>
[/code]
Re: Last modfied file time does not get.
Can you see/retrieve the time in any other SFTP client?
