Cannot reset SFTP login password with SessionOptions() using NewPassword or SecurePassword
james07030
United States
Hi everyone, I need help to reset SFTP server login password using C# WinSCP API automatically in the password expiration period. but either of the following method would not work:
1. Using NewPassword {} in SessionOptions API
Protocol = Protocol.Sftp,
HostName = hostName,
UserName = loginName,
Password = passwordOld,
NewPassword = passwordNew,
SshHostKeyFingerprint = fingerPrint,
session.Open(sessionOptions);
2. Using SecureNewPassword {} in SessionOptions API
SecurePassword = SecPasswordOld,
SecureNewPassword = SecPasswordNew,
3. Using passwordOld + "/" + passwordNew + "/" + passwordNew for login
//Protocol = Protocol.Ftp,
Password = passwordOld + "/" + passwordNew + "/" + passwordNew,
4. Using unix shell scrip "passwd" command
TransferOptions transferOptions = new TransferOptions();
transferOptions.TransferMode = TransferMode.Binary;
string passwordChange = passwordOld + "/" + passwordNew + "/" + passwordNew;
string comChangePass = string.Format("echo -n " + passwordChange + " | passwd");
CommandExecutionResult result = session.ExecuteCommand(comChangePass);
MessageBox.Show("Password change command : " + comChangePass);
result.Check();
string output = result.Output;
MessageBox.Show("Password changed result: " + output);
Anybody knows how to use WinScp API to change password by program?
Thank you very much!
James
Re: Cannot reset SFTP login password with SessionOptions() using NewPassword or SecurePassword
Sorry, but "would not work" is pretty vague. Can you post some log files?
Thank you so much, here is the log I have:
My Code:
My Error Log:
INFO 14 Sep 2018 10:52:48,367 FDCCPasswordReset.Program - Error! SFTP connection failed.WinSCP.SessionRemoteException: Connection has been unexpectedly closed. Server sent command exit status 0.
Using username "MyUserName1".
Access denied.
Authentication failed.
at WinSCP.SessionLogReader.Read(LogReadFlags flags)
at WinSCP.ElementLogReader.Read(LogReadFlags flags)
at WinSCP.SessionElementLogReader.Read(LogReadFlags flags)
at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.Session.WaitForGroup()
at WinSCP.Session.Open(SessionOptions sessionOptions)
at FICCPasswordReset.Program.Main(String[] args)
