Backup Stopping At Seemingly Random Points + Only Overwrite Modified Files
crimsonnight
Hey guys, I've set up the below script (based on guides I have found + checking the WinSCP documentation) to automatically backup all content on my server:
option echo on
option batch on
open CrimsonNight
synchronize local "E:\OneDrive\Website\Backups\WinSCP_FullServerBackup" /home
close
I've ran the script around 4 times now and it's backed up around half my content (4GB). The weird thing is, it stays open/backs up different amounts every time before randomly closing - how can I keep it open to complete the backup? It seems to start at the beginning every time so I'm not sure it'll ever complete at this point. On that note, is it overwriting files every time? I only want it to backup modified files (which I assume is the case as I've used the 'synchronize local' command but just wanted to confirm).
Thanks!
Re: Backup Stopping At Seemingly Random Points + Only Overwrite Modified Files
Please attach a session log file showing the problem (using the latest version of WinSCP).
It wasn't enabled in preferences at the time but I have enabled it now - do I leave it set to 'Normal' level? Also, it's obviously running through 'WinSCP.com' so I'm not sure if that'll effect the logging.
Apologies, I missed the text in the smaller font before. I've added the code to the batch file but it's saying:
Error occurred during logging. It's been turned off.
Can't open log file 'path_to_log_file'.
System Error. Code: 5.
Access is denied
The path_to_log_file should obviously be replaced by a "path to the log file". Like C:\path\to\log.log.
crimsonnight
UK
Hi there, I'm having problems attaching my 'log.txt' file - I'm getting the following message: 'No post mode specified'
What exactly are you doing, when you get this error?
You can send the logs to my email address.
