(GUI) Auto Retry on Error / haults remaning queue'd downloads?
hi,
(same issue as this post, although post is from 2013, and im now using the current non beta version- https://winscp.net/forum/viewtopic.php?t=12721 )
when downloading several files (batch/queued) some files (from a non-encrypted FTP server, ) occasionally the gui will popup and say: skip , retry or skip all.
(and most important, it haults all remaining downloads, which is the problem).
If i click retry, it then is able to download the problem file, and continues on with the remaining batch downloads.
is there a way to set winscp to auto retry X times maybe (or to move on to other DLs)?
(i tested the same server/files with filezilla client, and occasionally a file needs to be retried just like in winscp, but its does this automatically based upon my settings, and also continues the rest of the queue, so i do think its a winscp issue).
any ideas on how to fix this (or am i missing something in the settings)?
thanks
thanks
