Failure reading network stream
I have a program that creates two csv files daily. A script that I wrote using WinSCP assembly uploads those to a FTP server. Since yesterday this task fails.
I tried using the GUI version, but that fails, too. So it is not a problem with the assembly. I updated both to the latest version.
Some information:
The server uses vsftp with explicit encryption.
FileZilla uses extended passive mode and WinSCP "only" passive mode. As far as I see that shouldn't be the cause.
The error message on the server side:
WinSCP logs (I translated some entries into English myself):
The file gets created on the server and has the same size (in bit) as the local file. So it seems that the transfer itself was a success but it failed to successfully finish.
If further data is required I will gladly provide that.
Some information:
- - only one of the two csv files fail
- aside from some changes in lines I see no difference between the old (working) file and the new one that fails (start and end are identical in editor and hex editor)
- using FileZilla works, but that lacks the automation function
Tue Jul 23 10:03:31 2019 [pid 10202] [user] FTP response: Client "IP address", "200 Switching to Binary mode."
Tue Jul 23 10:03:31 2019 [pid 10202] [user] FTP command: Client "IP address", "PASV"
Tue Jul 23 10:03:31 2019 [pid 10202] [user] FTP response: Client "IP address", "227 Entering Passive Mode (138,201,251,140,239,139)."
Tue Jul 23 10:03:31 2019 [pid 10202] [user] FTP command: Client "IP address", "STOR file.csv"
Tue Jul 23 10:03:31 2019 [pid 10202] [user] FTP response: Client "IP address", "150 Ok to send data."
Tue Jul 23 10:03:31 2019 [pid 10201] [user] DEBUG: Client "IP address", "DATA connection terminated without SSL shutdown. Buggy client! Integrity of upload cannot be asserted."
Tue Jul 23 10:03:31 2019 [pid 10202] [user] FTP response: Client "IP address", "426 Failure reading network stream."
Tue Jul 23 10:03:31 2019 [pid 10202] [user] FAIL UPLOAD: Client "IP address", "/folder/file.csv", 327390 bytes, 3849.51Kbyte/sec
< 2019-07-23 11:48:36.028 200 Switching to Binary mode.
> 2019-07-23 11:48:36.028 PASV
< 2019-07-23 11:48:36.060 227 Entering Passive Mode (138,201,251,140,102,40).
> 2019-07-23 11:48:36.060 STOR file.csv
. 2019-07-23 11:48:36.060 connecting to IP_address:26152 ...
. 2019-07-23 11:48:36.075 Data connection opened
< 2019-07-23 11:48:36.106 150 Ok to send data.
. 2019-07-23 11:48:36.106 Data connection opened
. 2019-07-23 11:48:36.106 Trying reuse main TLS session ID
. 2019-07-23 11:48:36.106 TLS layer changed state from none to connected
. 2019-07-23 11:48:36.138 Session ID reused
. 2019-07-23 11:48:36.138 TLS connect: SSLv3 read server hello A
. 2019-07-23 11:48:36.138 TLS connect: SSLv3 read finished A
. 2019-07-23 11:48:36.138 TLS connect: SSLv3 write change cipher spec A
. 2019-07-23 11:48:36.138 TLS connect: SSLv3 write finished A
. 2019-07-23 11:48:36.138 TLS connect: SSLv3 flush data
. 2019-07-23 11:48:36.138 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA, ECDHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AESGCM(256) Mac=AEAD
. 2019-07-23 11:48:36.138 TLS connection established
< 2019-07-23 11:48:36.388 426 Failure reading network stream.
. 2019-07-23 11:48:36.388 file copy to remote machine failed.
. 2019-07-23 11:48:36.388 Got reply 4 to the command 4
* 2019-07-23 11:48:36.388 (ExtException) **file copy to remote machine failed.**
* 2019-07-23 11:48:36.388 Failure reading network stream.
