If the console has timed out, it will reconnect twice connection to open the console.
It is not a bug.
Please enhance the development of the convenient console (Shift + Ctrl + T hot key) function.
Once I have started the console and closed it,
Use Shift + Ctrl + T to try again, it so Good until the console starts quickly!
If the console has timed out, it will be prompted to reconnect.
By the way, after trying to reconnect by timeout, the console will be lost. Reconnection is wasted!
if it has timed out, it will reconnect twice to open the console.
I want to improve the console so that it can be reconnected smoothly at just after timeout.
My WinSCP : 5.15.9 Win10 Pro 64
