Host disconnecting in the middle of file transfer after establishing connection.
Bivek
Sikkim
I am trying to use winscp to upload files to a sftp server, I am able to successfully establish connection to the sftpserver but when I inititae the file transfer after some time it shows the following error:
-20210127.bak |      382307 KB | 1162.9 KB/s | binary |  30%
Host is not communicating for more than 15 seconds.
Still waiting...
Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
Warning: Aborting this operation will close connection!
(A)bort (60 s): Abort
20210127.bak |      382866 KB |  134.1 KB/s | binary |  30%
Terminated by user.
(A)bort, (R)econnect (5 s): Reconnect
Searching for host...
Connecting to host...
Authenticating...
Using username "****".
Authenticated.
Starting the session...
Session started.
20210127.bak |      382866 KB |  133.7 KB/s | binary |  30%
20210127.bak |      382901 KB |    0.0 KB/s | binary |  30%
Received SSH2_MSG_CHANNEL_DATA for nonexistent channel 0
So this continues until I abort the process
I have tried to turn off the optimize buffer option using -rawsettings FSProtocol=2 SendBuf=0 SshSimple=0
but still I am getting this error.
.bat file:
"C:\Program Files (x86)\WinSCP\winscp.com" /ini=nul /script=trial.txt /log=D:\Bivek\example.log
trial.txt:
(I cant show my username and password for security reasons)
open sftp:***/ -hostkey="***" -rawsettings FSProtocol=2 SendBuf=0 SshSimple=0
put -nopreservetime -resume "path_to_the_backup_file"
I am sharing the log file too
Any help is highly appreciated
  • logss.txt (13.04 KB, Private file)
Description: log txt
Re: Host disconnecting in the middle of file transfer after establishing connection.
Can you upload the file using any other SFTP client?
Bivek
Actually, I need the script to work using this sftp client only.
OK, but can you answer my question?
