WinSCP crashes after few seconds and WinSCP.exe vanishes
alexsunny123
india
I have the following problem. I start WinSCP by using the desktop Button. I enter password and all this stuff. Then after few seconds WinSCP finishes and if I try to start WinSCP again the winscp.exe file is away!
It has worked without any problems for two months, but now I can't start WinSCP. I downloaded any version of Winscp, but every time it's the same: After 10 seconds WinSCP finishes and winscp.exe is deleted. My system is Windows XP Pro. Do you have an idea?
thanks
alexsunny
Re: WinSCP crashes after few seconds and WinSCP.exe vanishes
WinSCP cannot delete itself. It's technically impossible. So it must be something else on your machine that deletes WinSCP, like an antivirus.
