PowerShell: Exception calling "Open" with "1" argument(s): "Connection has been unexpectedly closed"
Zeppelins2
USA
Entire Error:
Exception calling "Open" with "1" argument(s): "Connection has been unexpectedly closed. Server sent command exit status 0."
This works fine within WinSCP. Below is the PowerShell script that is experiencing this issue;
# Load WinSCP .NET assembly
Add-Type -Path "C:\<concealed local path>\WinSCPnet.dll"
# Set up session options
    HostName = "<concealed hostname>"
    UserName = "<concealed username>"
    Password = "<concealed password>"
    SshHostKeyFingerprint = "ssh-rsa 3072 <concealed fingerprint>"
try
    # Connect
    # Transfer files
    $session.GetFiles("/*", "\\<concealed UNC path>\*").Check()
finally
    $session.Dispose()
Re: Powershell: Exception calling "Open" with "1" argument(s): "Connection has been unexpectedly closed"
Please attach session log files both from the PowerShell code and WinSCP GUI.
Zeppelins2
Hello Martin, how would I go about getting the PowerShell info, and would posting this information reveal sensitive information? Can I instead email it directly?
Use Session.SessionLogPath. You can mark the logs as private attachments when posting them.
