WinSCP PowerShell Timeout Errors
We've been periodically receiving the following error message in our WinSCP log. The WinSCP executable is being called from a PowerShell script. This error seems to show up periodically and can usually be re-run. Does anyone have an idea why this might be happening
We also get the following exception from our PowerShell script:
. 2022-03-16 13:46:04.458 Connection was lost, asking what to do. * 2022-03-16 13:46:04.458 Timeout detected. (control connection) . 2022-03-16 13:46:04.458 Asking user: . 2022-03-16 13:46:04.458 Error transferring file *** ("Copying files to remote side failed.","Timeout detected. (control connection)") < 2022-03-16 13:46:04.458 Script: Error transferring file ***. < 2022-03-16 13:46:04.458 Script: Copying files to remote side failed.
The following is the PowerShell script:Exception calling "Check" with "0" argument(s): "Error transferring file ***. Copying files to remote side failed. Timeout detected. (control connection)"
$session_options = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::ftp HostName = *** UserName = *** SecurePassword = *** } try{ # Create logging file if($ftp_log){ $session.SessionLogPath = *** } $session_options.Timeout = New-TimeSpan -Seconds 30 # Connect $session.Open($session_options) # Upload files $transferOptions = New-Object WinSCP.TransferOptions $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary $transferResult = $session.PutFiles($local_directory, $remote_directory, $False, $transferOptions) # Throw on any error $transferResult.Check() # Print results foreach ($transfer in $transferResult.Transfers) { Write_Log -message "Uploaded $($transfer.FileName)" -severity 1 -smtp_enabled $false $upload_log+="<br>Upload of $($transfer.FileName) succeeded!" } $return_val = $true }finally{ # Disconnect, clean up $session.Dispose() } }catch{ return $false } $return_val = $true return $return_val
