Topic "WinSCP FTP explicitly send QUIT"
michaelskoerner
I'm using the WinSCP winscp.com to open a FTP session on a server, list the contents, and log off. When I check the FTP server, I see that the WinSCP client does not send a QUIT command when the session is closed. This keeps the session open on the server. So I added a "call quit" command to the script. However this results with the winscp.com throwing the error "Invalid access to memory", probably because the session is already closed
Is there a better way to send the QUIT from WinSCP?
Here is the command line:
winscp.com /script=test.txt /log=log.txt
Script:
option batch on
open ftp://user:pwd@site
ls
call HELP
call quit
Client is WinSCP Version 4.3.4 (Build 1428) (OS 6.1.7601 Service Pack 1)
Server is IIS ftp
I have sent you an email.
This issue was added to tracker:
http://winscp.net/tracker/show_bug.cgi?id=717
This bug was added to tracker:
http://winscp.net/tracker/show_bug.cgi?id=716
michaelskoerner
Thanks for investigating
