Contents » Using WinSCP » Guides » Scripting/Automation »
Advertisements:
This guide contains simplified description of automating operations on FTP/SFTP server with WinSCP. You may want to see detailed documentation of the scripting functionality instead.
There is also WinSCP .NET assembly build on top of the scripting interface. If you plan to call WinSCP from your .NET code, or if your task requires conditional processing, loops or other control structures, you should better use the .NET assembly. This guide focuses on simple automation tasks using scriting interface only.
Before starting you should:
Commands
Script file
Use the /script command line option to pass the script to the WinSCP executable. You can embed the complete command line into a Windows batch file (.bat), like as follows:
@echo off
winscp.com /script=myscript.txt
Advertisements:
Using script
  • Make shortcut to it on desktop to ease execution. Either make shortcut to batch file (.bat) or enter full command line to shortcut itself.
    • In a similar way you can put the shortcut to the batch file into Explorer’s ‘Send To’ context menu (c:\documents and settings\username\sendto).
Notes
When connecting to SSH host, you will need to accept its host key.
When connecting to FTPS host with certificate signed by untrusted authority you will need to verify the certificate.
option batch abort
open mysession
put %1%
winscp.com /script=script.tmp /parameter c:\myfile.txt
Alternatively, you can generate new script file each time. To automate that, make a wrapper script file. For simple tasks you can use built-in Windows scripting functionality from batch file (.bat). For complex tasks, you will need to use some scripting language, such JavaScript or VBScript from Windows scripting host or PHP or Perl.
rem Generate temporary script to upload %1
echo option batch abort > script.tmp
echo option confirm off >> script.tmp
echo open mysession >> script.tmp
echo put %1 >> script.tmp
echo exit >> script.tmp
rem Execute script
rem Delete temporary script
del script.tmp
upload.bat c:\myfile.txt
See more hints on using parameterised batch file.
See guide to advanced scripting for examples of script generation using more powerful languages.
Advertisements:
Checking script results
  • Save and inspect log file. XML log format is recommended. Use command-line parameter /log.
Once you find out what was the result of the script, you can perform any action you like. E.g. after evaluating exit code of WinSCP, you can send a “success” or “error” email. For that use any command-line email client you like, e.g. sendmail:
winscp.com /script=example.txt
if errorlevel 1 goto error
echo Success
sendmail.exe -t < success_mail.txt
goto end
:error
echo Error!
sendmail.exe -t < error_mail.txt
:end
Where for example content of success_mail.txt may be:
To: me@example.com
Subject: Success
The files were uploaded successfully.
See guide to advanced scripting for examples of checking script results (including XML log parsing) using more powerful languages and guide to interpreting XML log for advanced scripting using C# language.
Example
Further reading
  guide_automation.txt · Last modified: 6 Jan 2012 by prikryl
Search Documentation
This page
Associations
Site design by Black Gate
