Topic "copy a file from a windows machine to a linux machine"
kmcguine
I am trying to use a command line to copy a file from a windows machine to a linux machine, but I can not get to file to copy to a different directory other than the home directory. The command line I am using is:
"c:\Program Files (x86)\WinSCP\winscp.exe" /command "option batch on" "option confirm off" "open userid:password@remotelinuxmachine" "put C:\Users\tuxadm\psft\pt\8.51\appserv\prcs\PSNTDEV\log_output\SQR_CNXMF017_2435611\CNXMF017_2435611*.PDF" "cd /home/psoft/psreports/devcop/" "/log=C:\Users\tuxadm\test.log" "exit"
The script works fine except that I can't copy to /home/psoft/psreports/devcop/, it copies to /home/psoft/ .
Karen
Use:
"put C:\Users\tuxadm\psft\pt\8.51\appserv\prcs\PSNTDEV\log_output\SQR_CNXMF017_2435611\CNXMF017_2435611*.PDF /home/psoft/psreports/devcop/"
Thanks, I was having trouble where to place the quotes. After making your suggested change, I am still having trouble. I'd like to copy the entire directory. Can I do this? Do the wildcards work with the put command?
"put C:\Users\tuxadm\psft\pt\8.51\appserv\prcs\PSNTDEV\log_output\SQR_CNXPO404_2437814\*.* /home/psoft/psreports/devcop/"
prikryl wrote:
Use:
I believe the problem may be related to winscp is running under the "system" account. I need it to run under the user I am logged into the machine as.
Do you have any suggestions?
prikryl wrote:
Use:
You seem to have the command right.
Not sure what kind of suggestion you ask for.
Dennisdr
Karen
Very Happy
It help us a lot in making a batch file....thank a lot
