Topic "SFTP Upload - No Error Seen"
mathsci
I am having an isuse with the script below. I can connect to the vendor's server with my login credentials in either WinSCP or FileZilla but when I try the script from the command line
(winscp.exe /console /log /script=c:\C:\Program Files\WinSCP\myscript.txt), I see a flash and then nothing. I am opviously doing someting dumb, but cannot determine what it is after 6 hours looking at guides, etc. Since I have used WinSCP to do a transfer with a previous vendor who did not use a password, I suspect that is the problem.
Any assistance would be appreciated
WinSCP - 4.3.4 (Build 1428)
OS- Windows 2003 Server Std SP 2
option batch on
open Username:password@company.com :22
option transfer binary
cd /
cd /home/delnorte
put C:\Local_Folder\contacts.txt
put C:\Local_Folder\courses.txt
put C:\Local_Folder\enrollment.txt
put C:\Local_Folder\mastschd.txt
put C:\Local_Folder\programs.txt
put C:\Local_Folder\roster.txt
put C:\Local_Folder\sites.txt
put C:\Local_Folder\studemo.txt
put C:\Local_Folder\terms.txt
put C:\Local_Folder\transcripts.txt
put C:\Local_Folder\users.txt
# Disconnect
close
# Exit WinSCP
mathsci
Any thoughts?
mathsci
This is now working. I made 2 fairly dumb errors, both of which I should have figured out earlier.
In Scheduled Tasks, file paths have to be quoted since there are spaces in the paths (Program Files).
"C:\Program Files\WinSCP\WinSCP.exe" /console /script="C:\Program Files\WinSCP\myscript.txt" works.
The open command in the script has to be:
open sftp:username:password@company.com
The port augment I was using (:22) does not seem to work or be needed.
Hope this helps someone -
mathsci
PS - this is an EXCELLENT program - Thanks!
