Topic "Executing a shell script (program) on remote UNIX server."
joelignall
Hello, I saw one topic answered in the negative but I figured I'd give this a shot anyway. Does anyone know how to run a shell script (program) on a remote UNIX server? The SSH Windows XP version we use (Tectia) has the following sytanx for running remote scripts;
"ssh2 UserID@Machine /alps/system/ialps_remove.ksh"
Thanks!
So do you want to execute the script with WinSCP, instead of with Tectia?
You can do it this way:
winscp.com /command "open UserID@Machine" "call /alps/system/ialps_remove.ksh"
joelignall
Thank you very much, extremely helpful. I only had to tweak what you sent slightly in order to have passwordless execution (no prompts). In case it helps anyone else, here is my sample.
winscp.com /command "open username:pw@servername" "call /home/x104150/testscript.ksh" "exit"
Thanks again!!!
