Topic "Add Servername to the temp file path"
consistency
winscp creates the following file on edit:
C:\Users\username\AppData\Local\Temp\scp12499\etc\nginx\nginx.conf
if i manage a lot of servers (failover), i end up having 4 files open like
C:\Users\username\AppData\Local\Temp\scp12500\etc\nginx\nginx.conf
C:\Users\username\AppData\Local\Temp\scp12501\etc\nginx\nginx.conf
C:\Users\username\AppData\Local\Temp\scp12502\etc\nginx\nginx.conf
i cant see in my editor, if the file which i opened is from server "servername1" or "servername2" or....
so it would be cool, to just add the servername or the host to the temp path like
C:\Users\username\AppData\Local\Temp\winscp\12500\servername1\etc\nginx\nginx.conf
C:\Users\username\AppData\Local\Temp\winscp\12501\servername1\etc\nginx\nginx.conf
the numbers (12500 and 12501) can be kept or striped if not needed.
Please read documentation:
http://winscp.net/eng/docs/ui_pref_storage#temporary_directory
consistency
thank you for pointing me the right way Smile
don't thought that you allready implemented that.
