Topic "Downloaded file has extra data in it."
Jmiller76
Issue occures for 4.1 (old copy) and 5.0.5.1782.
I do not have control of the server, but I am told that it is some version of appache and that "thousands of uses have no issues."
The problem happens for all (5) files under the user account.
WinSCP.EXE reports file size as 5,271 B.
When the file is downloaded it begins to repeat from the middle of the file after it should be ended. Resulting in a file that WIn7 reports as 6446 bytes(size).
For any sample file, the end of the result file contains the correct data for the end of the file. It seems more like a hiccup then it finishes again.
I have a Log level 2 file that I can forward to Martin directly.
The file seems to finish then starts back up after:
. 2011-12-09 12:50:12.619 Sent 61 bytes
. 2011-12-09 12:50:12.619 There are 0 bytes remaining in the send buffer
. 2011-12-09 12:50:12.619 Looking for network events
. 2011-12-09 12:50:12.619 Timeout waiting for network events
. 2011-12-09 12:50:12.619 Session upkeep
. 2011-12-09 12:50:12.621 Read 4 bytes (1185 pending)
. 2011-12-09 12:50:12.621 Read 1185 bytes (0 pending)
< 2011-12-09 12:50:12.621 Type: SSH_FXP_DATA, Size: 1185, Number: 2053
Josh
Forgot to mention if I use PSFTP for the transfer, the file comes down corret.
Thank you, Josh
I have sent you an email with a debug version.
