Topic "Switching between filenames using the keyboard"
zack4x4
Hi - I'm running v4.3.5 (Build 1463) using the FTP protocol. When I close out of a file for instance I key in the next file I want to edit and Press F4 however the original file stays highlighted and when I press the spacebar to highlight the new file, the original file also stays highlighted. So consequently when I press F4 it downloads both files for edit. It's kind of an annoying bug because I use the keyboard in Winscp so much as opposed to the mouse.
Thanks!
Zack
You should avoid highlighting the first file. Focus (the rectangle) is just enough (if there's no other selection) to tell WinSCP what file to edit.
Please read FAQ:
https://winscp.net/eng/docs/ui_commander#selecting_files
I will have to do a video capture because I don't think you understand what I mean. Thanks though
Zack
OK.
