Unable to send file betwen Wxp and stb(linux)
dstb1
I try to send files from Win XP to DreamBox but WinSCP crashes
There is log
. 2011-12-16 21:07:52.262 Session upkeep
. 2011-12-16 21:07:52.762 Session upkeep
. 2011-12-16 21:07:52.856 Copying 1 files/directories to remote directory "/var/bin/"
. 2011-12-16 21:07:52.856   PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2011-12-16 21:07:52.856   TM: M; ClAr: No; ExclM(No):
. 2011-12-16 21:07:52.856   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2011-12-16 21:07:52.856 Sent 103 bytes
. 2011-12-16 21:07:52.856 There are 0 bytes remaining in the send buffer
. 2011-12-16 21:07:52.856 Sent 1 bytes
> 2011-12-16 21:07:52.856 echo "WinSCP: this is begin-of-file" ; scp -r  -d -t "/var/bin" ; echo "WinSCP: this is end-of-file:$?"
. 2011-12-16 21:07:52.856 Waiting for another 1 bytes
. 2011-12-16 21:07:52.934 Detected network event
. 2011-12-16 21:07:52.934 Received 31 bytes (0)
. 2011-12-16 21:07:52.934 Read 1 bytes (30 pending)
. 2011-12-16 21:07:52.934 Read 29 bytes (1 pending)
< 2011-12-16 21:07:52.934 WinSCP: this is begin-of-file
. 2011-12-16 21:07:52.934 Read 1 bytes (0 pending)
. 2011-12-16 21:07:52.934 SCP remote side confirmation (0)
. 2011-12-16 21:07:52.934 File: "C:\Documents and Settings\User\Desktop\New Text Document.txt"
. 2011-12-16 21:07:53.262 Copying "C:\Documents and Settings\User\Desktop\New Text Document.txt" to remote directory started.
. 2011-12-16 21:07:53.262 Session upkeep
. 2011-12-16 21:07:53.293 Ascii transfer mode selected.
. 2011-12-16 21:07:53.324 Sent 26 bytes
. 2011-12-16 21:07:53.324 There are 0 bytes remaining in the send buffer
. 2011-12-16 21:07:53.324 Sent 1 bytes
> 2011-12-16 21:07:53.324 T1323802496 0 1324062370 0
. 2011-12-16 21:07:53.324 Waiting for another 1 bytes
. 2011-12-16 21:07:53.356 Detected network event
. 2011-12-16 21:07:53.371 Received 1 bytes (0)
. 2011-12-16 21:07:53.371 Read 1 bytes (0 pending)
. 2011-12-16 21:07:53.371 SCP remote side confirmation (0)
. 2011-12-16 21:07:53.371 Sent 31 bytes
. 2011-12-16 21:07:53.371 There are 0 bytes remaining in the send buffer
. 2011-12-16 21:07:53.371 Sent 1 bytes
> 2011-12-16 21:07:53.371 C0644 280 New Text Document.txt
. 2011-12-16 21:07:53.371 Waiting for another 1 bytes
. 2011-12-16 21:07:53.403 Detected network event
. 2011-12-16 21:07:53.403 Received 1 bytes (0)
. 2011-12-16 21:07:53.403 Read 1 bytes (0 pending)
. 2011-12-16 21:07:53.403 SCP remote side confirmation (0)
. 2011-12-16 21:07:53.403 Sending ASCII data (280 bytes)
. 2011-12-16 21:07:53.403 Sent 280 bytes
. 2011-12-16 21:07:53.403 There are 0 bytes remaining in the send buffer
. 2011-12-16 21:07:53.403 Sending NULL.
. 2011-12-16 21:07:53.403 Sent 1 bytes
. 2011-12-16 21:07:53.403 Waiting for another 1 bytes
. 2011-12-16 21:07:53.449 Detected network event
. 2011-12-16 21:07:53.449 Received 116 bytes (1)
! 2011-12-16 21:07:53.449 scp: relocation error: scp: symbol utimes, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
. 2011-12-16 21:07:53.449 Waiting for another 1 bytes
. 2011-12-16 21:07:53.465 Detected network event
. 2011-12-16 21:07:53.465 Received 32 bytes (0)
. 2011-12-16 21:07:53.465 Read 1 bytes (31 pending)
. 2011-12-16 21:07:53.465 Read 31 bytes (0 pending)
< 2011-12-16 21:07:53.465 inSCP: this is end-of-file:127
. 2011-12-16 21:07:54.168 Session upkeep
Regards
Re: Unable to send file betwen Wxp and stb(linux)
There's something wrong with scp installation on your server:
Can you try SFTP instead?
Also how does the WinSCP crash manifest?
WinSCP crashes imeditly when file copied. File is copied corectly. But after that program crashes. Everytime when try to copy something.
You can browse folders and there`s no probs.
Regards
