Topic "Old versions of winscp available for download?"
undercover
Hi there,
are there any old versions of winscp (e.g. 3.5; _without_ the windows shells extensions) available for download?
Kind regards,
undercover
Why do you ask?
If the extension does not work for you, I would rather like to know what it does. Otherwise I can hardly fix it Sad
If you just do not want to install the extension to your system, you do not have you. WinSCP can work even without it. It will use old approach using temporary directory, just as 3.5 and older.
Please, let me know.
Anyway, old versions can be donwloaded from Sourceforge download server. The link is on Downloads page.
