File Permissions
mwinner
File Permissions
Does anybody know why, when I use:
transferOptions.FilePermissions.Numeric = 775
I get an error pointing to: transferOptions.FilePermissions.Numeric = 775, saying "Object reference not set to an instance of an object."? It works perfectly without it, but I need certain permissions set. No matter how I set such permissions, it doesn't seem to work.
Thanks!
Re: File Permissions
TransferOptions.FilePermissions defaults to Null.
So you need to create an instance of FilePermissions first:
Set transferOptions.FilePermissions = New FilePermissions
Then, you probably wanted to do:
transferOptions.FilePermissions.Octal = "755"
