Topic "uploading a file through command line with SSH"
Greg T
Been wrestling with this all morning and hit a point where I need to raise my hand for some assistance.
Here is my line I'm running and output
winscp /command "option batch abort" "option confirm off" "open s -hostkey="ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" "put -nopreservetime tester.txt" "exit"
Searching for host...
Host does not exist
batch abort
confirm off
Connecting to host...
Using username "user".
Starting the session...
Reading remote directory...
Session started.
Active session: [1]
Unknown command '1024'.
when I run it in these chunks it works without issue. Just combined it complains. Any thoughts?
so I'm thinking it's syntax at this point. I just don't see it at this point. Any help?
You need to double the double-quotes around command arguments:
winscp /command "option batch abort" "option confirm off" "open s -hostkey=""ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx""" "put -nopreservetime tester.txt" "exit"
