Topic "Error: Exception: System.IO.IOException:"
jmsunseri
When I try to open a session i get the following error in my logs
[2012-05-11 13:25:19Z] [0004] Executing Assembly: WinSCP, Version=1.0.0.235, Culture=neutral, PublicKeyToken=XXXXXXXXXXXXXXX; Path: D:/XmlProcessorService/bin/WinSCP.DLL; Location: D:\XmlProcessorService\bin\WinSCP.dll; Product: 5.0.6.0
[2012-05-11 13:25:19Z] [0004] Entry Assembly: XMLProcessorService, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
[2012-05-11 13:25:19Z] [0004] Operating system: Microsoft Windows NT 5.2.3790 Service Pack 1
[2012-05-11 13:25:19Z] [0004] User: _svc_maed@XXXXXXXXXX@XXXXXXXXXX; Interactive: False
[2012-05-11 13:25:19Z] [0004] Runtime: 2.0.50727.1433
[2012-05-11 13:25:19Z] [0004] Console encoding: Input: Western European (Windows) (1252); Output: Western European (Windows) (1252)
[2012-05-11 13:25:19Z] [0004] Session.Open entering
[2012-05-11 13:25:28Z] [0004] Exception: System.IO.IOException: The file exists.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.__Error.WinIOError()
at System.IO.Path.GetTempFileName()
at WinSCP.Session.Open(SessionOptions sessionOptions)
[2012-05-11 13:25:28Z] [0004] Session.Cleanup entering
[2012-05-11 13:25:28Z] [0004] Session.Cleanup leaving
[2012-05-11 13:25:28Z] [0004] Session.Open leaving
[2012-05-11 13:25:28Z] [0004] Session.Open entering
[2012-05-11 13:25:37Z] [0004] Exception: System.IO.IOException: The file exists.
[2012-05-11 13:25:37Z] [0004] Session.Cleanup entering
[2012-05-11 13:25:37Z] [0004] Session.Cleanup leaving
[2012-05-11 13:25:37Z] [0004] Session.Open leaving
[2012-05-11 13:25:37Z] [0004] Session.PutFiles entering
[2012-05-11 13:25:37Z] [0004] Session.PutFiles leaving
[2012-05-11 13:25:37Z] [0004] Session.Dispose entering
I've noticed that it is in consistent in that the same code will produce different results depending on the computer is is being run from. On my machine I have no problem establishing a connection to the remote server. When I run my code from my production server I get the above error. Any help would be greatly appreciated.
Justin
jmsunseri
It should also be said that I am doing this using the SFTP protocol and the .Net assembly version 5.0.6.
Duplicate post:
http://winscp.net/forum/viewtopic.php?t=11189
prikryl wrote:
This url does not work.
I got the same problem - would really appreciate help on this one.
ted1001
The error is because temp folder is filled with tmp files created by Winscp.
Remove these and it will work.
(On a MS Server 2008, the files were create here: C:\Users\<useraccount>\AppData\Local\Temp
You need to login to access it.
Anyway, upgrade to 5.0.7 beta.
http://winscp.net/tracker/show_bug.cgi?id=849
