Topic "winscp is not generating the log file when used with .NET"
I have followed the guidelines on
.NET Process initially complained about not being able to locate to run it,
so I moved the file to the right location, so I know it is running winscp now.
I have put in some scripting for the winscp Process to run.
Problem now is it's not generating the log.xml. I have no idea where I made mistakes in the scripts.
The code
XPathDocument log = new XPathDocument("log.xml");
throws an IO.FileNotFoundException saying log.xml could not be found.
Can you post more code? What version of WinSCP are you using?
Also, you should better use WinSCP .NET assembly anyway:
