Topic "Permissions"
velastin
I am running latest version (3-5-6 Build 213).
I connect successfully to two systems running Mandrake 9.1
When trying to set file/diretory permissions the owner and group boxes appear greyed and cannot be changed. This does not happen before. I am running from an Windows XP computer that has a Novel client installed (problem still happens even if I dont login to a Novell tree).
Any ideas?
This does not happen at home (no Novell and I might be running an earlier version of WinSCP)
Sergio Velastin
Digital Imaging Research Centre
Kingston University (UK)
Changing of owner/group is allowed only with SCP and SFTP above version 4.
See Supported transfer protocols.
velastin
Thanks Martin. I am connecting to the same Linux system (BTW I connect as root) now from home running WinSCP 3.3.0 Build 177 also on Windows XP Pro. This now allows me to change owner and permissions. Puzzled?
Sergio Velastin
I suppose that at home you are using SCP, while you're using SFTP on the other site. Note that SFTP is the default transfer protocol since 3.5
velastin
Dear Martin.
Bingo! Yes. I had not realised that new version defaults to SFTP. Setting it to SCP now allows me to change owner and group. Many thanks.
Sergio Velastin
