Topic "Connect to a specific folder ?"
Thananas
Hi there !
I'm connecting (with IE/FF or Chrome) on a certain ftp with this URL : ftp://XXXXX:21/public
The access is anonymous, but with WinSCP I don't manage to connect to it, and the problem is simple, I can't specify a specific foler to connect to :/
With my navigator, if I only use the URL : ftp://XXXXX:21 I have en error message because the root folder is not accessible via an anonymous access, so can I configure WinSCP to connect anonymously on a specific folder ?
Thanks in advance for your answers Smile
(ps : sorry if my description is bad, I'm Belgian...)
(ps2 : Im using WinSCP 4.0.3, yeah this version is old as hell but I'm affraid to lose all my saved sessions if I upgrade to the last version :/ of course if you are 100% sure that I can update my client without losing my stored sessions AND that this is the only way - cause 4.0.3 version don't do it - tahn just tell me ^^)
Specify initial remote diectory on Directories page of login dialog:
http://winscp.net/eng/docs/ui_login_directories
Jungleboogie
Is there a way of doing this using Winscp.com? /via command line as I need to automate my get.
Can you also enforce active mode via winscp.com?
Cheers,
JB.
Yes, please read documentation:
http://winscp.net/eng/docs/scriptcommand_open
http://winscp.net/eng/docs/scriptcommand_cd
