Unable to connect with SFTP using 5.0.7 beta....
djoy
United States
First off, I'm new to WinSCP, I've only been working with it 2 days but have digested a lot of information that has been helpful but am now stuck.
I have developed a VB.NET Windows Service running under XP. I need to transfer files to a secured FTP site so have downloaded your VB.NET Assembly. I initially downloaded 4.3.8 of WinSCP but when I first attempted to connect with the VB.NET it told me the versions did not match so I downloaded and installed 5.0.7 of WinSCP. I'm able to connect to my server with the GUI and transfer files. Each time I connect I get a warning about connecting to the server but then it connects and I can transfer files. From VB.NET I get the message "Connection has been unexpectedly closed. Server sent command exit status 0.". I viewed your error list but nothing seemed to help.
Next I produced a log using Session.SessionLogPath and it appears that it's expecting a Password? Why when I've provided it with a Host Key? I've used the GUI so I know the username is correct and connected leaving the password blank. I'll post my code first (with security info removed) and then the log.
Thanks in advance.
With sessionOptions
.Protocol = Protocol.Sftp
.HostName = SFTPServerName
.UserName = Username
.Password = ""
.SshHostKey = SFTPServerKey
End With
Using session As Session = New Session
' Connect
session.SessionLogPath = OutputFolder & "WinSCP.log"
session.Open(sessionOptions)
' Upload files
transferResult = session.PutFiles(FileToBeSent, SFTPServerDir, False, transferOptions)
' Throw on any error
transferResult.Check()
' Print results
Dim transfer As TransferEventArgs
For Each transfer In transferResult.Transfers
bErr = util.SaveTextToFile(Now().ToString & " Transferred: " & FileToBeSent & ".", OutputFolder & "Transactions.log", ErrInfo)
Next
End Using
. 2012-06-28 19:40:42.953 Looking up host "sftp.xxxxx.com"
. 2012-06-28 19:40:42.953 Connecting to 99.999.999.999 port 22
. 2012-06-28 19:40:43.046 Server version: SSH-2.0-1.36 sshlib: GlobalScape
. 2012-06-28 19:40:43.046 We believe remote version ignores SSH-2 maximum packet size
. 2012-06-28 19:40:43.046 Using SSH protocol version 2
. 2012-06-28 19:40:43.046 We claim version: SSH-2.0-WinSCP_release_5.0.7
. 2012-06-28 19:40:43.093 Using Diffie-Hellman with standard group "group1"
. 2012-06-28 19:40:43.093 Doing Diffie-Hellman key exchange with hash SHA-1
. 2012-06-28 19:40:43.421 Verifying host key dss 0xb92c47e49b8df5f80c1740a0c38021eb1cead9b982...
. 2012-06-28 19:40:43.421 Host key matches configured key
. 2012-06-28 19:40:43.421 Host key fingerprint is:
. 2012-06-28 19:40:43.421 ssh-dss 1024 86:08:93:00:55:be:b5:0c:3c:92:97:85:3f:f4:09:46
. 2012-06-28 19:40:43.421 Initialised Blowfish-128 CBC client->server encryption
. 2012-06-28 19:40:43.421 Initialised HMAC-SHA1 client->server MAC algorithm
. 2012-06-28 19:40:43.421 Initialised Blowfish-128 CBC server->client encryption
. 2012-06-28 19:40:43.421 Initialised HMAC-SHA1 server->client MAC algorithm
! 2012-06-28 19:40:43.671 Using username "username@sftpserver.com".
. 2012-06-28 19:40:43.718 Prompt (7, SSH password, , &Password: )
. 2012-06-28 19:40:43.718 Disconnected: Unable to authenticate
Re: Unable to connect with SFTP using 5.0.7 beta....
Maybe you are confuing a host key fingerpring with a private key path. Hostkey is not used for authentication.
djoy
Thanks for the advice. I added the SshPrivateKey property and it's now transferring data.
