Topic "authentication failed, enter password"
mckinneyalan@...
version 3.7.6 tries to connect and asks for the password. Type it in and continues to cycle asking for the password.
I installed version 4.3.9 and received the same results:
On one machine (windows XP) it works properly with version 3.7.6. On a windows 7 Ultimate computer it cycles asking fof the password. It had been working properly on this computer until today.
Below is the log file from the attempt on the windows 7 uplimate computer: Thanks in advance, on any help on how to proceed.
. 2012-08-06 15:18:03.630 --------------------------------------------------------------------------
. 2012-08-06 15:18:03.630 WinSCP Version 4.3.9 (Build 1817) (OS 6.1.7601 Service Pack 1)
. 2012-08-06 15:18:03.630 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2012-08-06 15:18:03.646 Local account: CPI\swaters
. 2012-08-06 15:18:03.646 Login time: Monday, August 06, 2012 3:18:03 PM
. 2012-08-06 15:18:03.646 --------------------------------------------------------------------------
. 2012-08-06 15:18:03.646 Session name: 4432@claims.ncmedicaid.com (Modified stored session)
. 2012-08-06 15:18:03.646 Host name: claims.ncmedicaid.com (Port: 22)
. 2012-08-06 15:18:03.646 User name: 4432 (Password: No, Key file: No)
. 2012-08-06 15:18:03.646 Tunnel: No
. 2012-08-06 15:18:03.646 Transfer Protocol: SFTP (SCP)
. 2012-08-06 15:18:03.646 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2012-08-06 15:18:03.646 Proxy: none
. 2012-08-06 15:18:03.646 SSH protocol version: 2; Compression: No
. 2012-08-06 15:18:03.646 Bypass authentication: No
. 2012-08-06 15:18:03.646 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2012-08-06 15:18:03.646 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2012-08-06 15:18:03.646 SSH Bugs: A,A,A,A,A,A,A,A,A
. 2012-08-06 15:18:03.646 SFTP Bugs: A,A
. 2012-08-06 15:18:03.646 Return code variable: Autodetect; Lookup user groups: Yes
. 2012-08-06 15:18:03.646 Shell: default
. 2012-08-06 15:18:03.646 EOL: 0, UTF: 2
. 2012-08-06 15:18:03.646 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2012-08-06 15:18:03.646 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2012-08-06 15:18:03.646 Local directory: Z:\, Remote directory: home, Update: No, Cache: Yes
. 2012-08-06 15:18:03.646 Cache directory changes: Yes, Permanent: Yes
. 2012-08-06 15:18:03.646 DST mode: 1
. 2012-08-06 15:18:03.677 Looking up host "claims.ncmedicaid.com"
. 2012-08-06 15:18:03.692 Connecting to 66.193.222.143 port 22
. 2012-08-06 15:18:03.755 Server version: SSH-2.0-VShell_3_8_3_292 VShell
. 2012-08-06 15:18:03.755 Using SSH protocol version 2
. 2012-08-06 15:18:03.755 We claim version: SSH-2.0-WinSCP_release_4.3.9
. 2012-08-06 15:18:03.802 Doing Diffie-Hellman group exchange
. 2012-08-06 15:18:04.036 Doing Diffie-Hellman key exchange with hash SHA-1
. 2012-08-06 15:18:04.316 Host key fingerprint is:
. 2012-08-06 15:18:04.316 ssh-dss 1024 6c:b2:98:da:8a:1b:94:fd:1d:09:50:89:55:b2:15:4f
. 2012-08-06 15:18:04.316 Initialised AES-256 SDCTR client->server encryption
. 2012-08-06 15:18:04.316 Initialised HMAC-SHA1 client->server MAC algorithm
. 2012-08-06 15:18:04.316 Initialised AES-256 SDCTR server->client encryption
. 2012-08-06 15:18:04.316 Initialised HMAC-SHA1 server->client MAC algorithm
! 2012-08-06 15:18:04.582 Using username "4432".
. 2012-08-06 15:18:04.675 Prompt (7, SSH password, , &Password: )
. 2012-08-06 15:18:08.528 Sent password
. 2012-08-06 15:18:08.653 Password authentication failed
! 2012-08-06 15:18:08.653 Access denied
. 2012-08-06 15:18:08.653 Prompt (7, SSH password, , &Password: )
. 2012-08-06 15:18:11.212 Disconnected: Unable to authenticate
* 2012-08-06 15:18:11.227 (ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 0.
* 2012-08-06 15:18:11.227 Authentication log (see session log for details):
* 2012-08-06 15:18:11.227 Using username "4432".
* 2012-08-06 15:18:11.227 Access denied.
* 2012-08-06 15:18:11.227 Authentication failed.
. 2012-08-06 15:18:34.503 --------------------------------------------------------------------------
. 2012-08-06 15:18:34.503 WinSCP Version 4.3.9 (Build 1817) (OS 6.1.7601 Service Pack 1)
. 2012-08-06 15:18:34.503 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2012-08-06 15:18:34.549 Local account: CPI\swaters
. 2012-08-06 15:18:34.549 Login time: Monday, August 06, 2012 3:18:34 PM
. 2012-08-06 15:18:34.549 --------------------------------------------------------------------------
. 2012-08-06 15:18:34.549 Session name: 4432@claims.ncmedicaid.com (Modified stored session)
. 2012-08-06 15:18:34.549 Host name: claims.ncmedicaid.com (Port: 22)
. 2012-08-06 15:18:34.549 User name: 4432 (Password: No, Key file: No)
. 2012-08-06 15:18:34.549 Tunnel: No
. 2012-08-06 15:18:34.549 Transfer Protocol: SFTP (SCP)
. 2012-08-06 15:18:34.549 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2012-08-06 15:18:34.549 Proxy: none
. 2012-08-06 15:18:34.549 SSH protocol version: 2; Compression: No
. 2012-08-06 15:18:34.549 Bypass authentication: No
. 2012-08-06 15:18:34.549 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2012-08-06 15:18:34.549 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2012-08-06 15:18:34.549 SSH Bugs: A,A,A,A,A,A,A,A,A
. 2012-08-06 15:18:34.549 SFTP Bugs: A,A
. 2012-08-06 15:18:34.549 Return code variable: Autodetect; Lookup user groups: Yes
. 2012-08-06 15:18:34.549 Shell: default
. 2012-08-06 15:18:34.549 EOL: 0, UTF: 2
. 2012-08-06 15:18:34.549 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2012-08-06 15:18:34.549 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2012-08-06 15:18:34.549 Local directory: Z:\, Remote directory: home, Update: No, Cache: Yes
. 2012-08-06 15:18:34.549 Cache directory changes: Yes, Permanent: Yes
. 2012-08-06 15:18:34.549 DST mode: 1
. 2012-08-06 15:18:34.581 Looking up host "claims.ncmedicaid.com"
. 2012-08-06 15:18:34.596 Connecting to 66.193.222.143 port 22
. 2012-08-06 15:18:34.659 Server version: SSH-2.0-VShell_3_8_3_292 VShell
. 2012-08-06 15:18:34.659 Using SSH protocol version 2
. 2012-08-06 15:18:34.659 We claim version: SSH-2.0-WinSCP_release_4.3.9
. 2012-08-06 15:18:34.690 Doing Diffie-Hellman group exchange
. 2012-08-06 15:18:34.877 Doing Diffie-Hellman key exchange with hash SHA-1
. 2012-08-06 15:18:35.267 Host key fingerprint is:
. 2012-08-06 15:18:35.267 ssh-dss 1024 6c:b2:98:da:8a:1b:94:fd:1d:09:50:89:55:b2:15:4f
. 2012-08-06 15:18:35.267 Initialised AES-256 SDCTR client->server encryption
. 2012-08-06 15:18:35.267 Initialised HMAC-SHA1 client->server MAC algorithm
. 2012-08-06 15:18:35.267 Initialised AES-256 SDCTR server->client encryption
. 2012-08-06 15:18:35.267 Initialised HMAC-SHA1 server->client MAC algorithm
! 2012-08-06 15:18:35.532 Using username "4432".
. 2012-08-06 15:18:35.626 Prompt (7, SSH password, , &Password: )
. 2012-08-06 15:18:41.211 Sent password
. 2012-08-06 15:18:41.289 Password authentication failed
! 2012-08-06 15:18:41.289 Access denied
. 2012-08-06 15:18:41.289 Prompt (7, SSH password, , &Password: )
. 2012-08-06 15:18:43.192 Disconnected: Unable to authenticate
* 2012-08-06 15:18:43.207 (ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 0.
* 2012-08-06 15:18:43.207 Authentication log (see session log for details):
* 2012-08-06 15:18:43.207 Using username "4432".
* 2012-08-06 15:18:43.207 Access denied.
* 2012-08-06 15:18:43.207 Authentication failed.
MHADDOCK
Last evening, I used the WinSCP to send my claims to nc medicaid. However, I was showing someone else how to use it for when I go on vacation this morning and it will not let me on. It keeps denying my password and access is denied. I have since downloaded the newest version and am still getting the same denial. Is there something that has changed or is something wrong with the WinSCP?
Duplicate post:
http://winscp.net/forum/viewtopic.php?t=11474
