Topic "automation"
IanS
I am a total novice here, read (tried to) some of the help files, and am now completely confused.
I need to download a backup of a database twice a week with simple FTP. I have set that up in Windows Tasks (Windows 7), no problem. It starts the winscp application no problem.
but then... I have the script as follows, each command is on a seperate line: User name, password,cd location (which file to look in on the server), lcd location (where to put the downloaded file), prompt, mget xxxxxxx.db, close, quit.
Where do I put this script so that it will actually open winSCP and download the database, and do I need to add/remove bits from it?
the initial session on WinSCP was saved as a default.
Please start by reading basic guides:
http://winscp.net/eng/docs/guide_automation
http://winscp.net/eng/docs/guide_schedule
Your script will look like:
option batch on
open ftp://username:password@hostname/
cd location
lcd location
get xxxxxxx.db
andegre
In your Windows Task Scheduler, the command that needs to be run should look something like this:
"C:\Program Files\WinSCP\WinSCP.com" /script="yourscript.txt"[/quote]
