Topic "5.0.8 RC: dir/stat issues (FTPS against FileZilla server)"
yaoops
Using FTPS implicit against FileZilla Windows server.
simple 'ls' yields on 5.0.6 beta:
winscp> ls
D--------- 0 0 ..
-rw-r--r-- 0 ftp ftp 6801 Jun 4 2012 OSstatus20120821121325.txt
-rw-r--r-- 0 ftp ftp 6801 Jun 4 2012 OSstatus20120824101325.txt
'stat' on 5.0.6 beta:
winscp> stat OSstatus20120821121325.txt
5.0.8 RC fails permission-wise:
winscp> ls
D--------- 0 0 ..
---------- 0 6801 Jun 4 11:58:52 2012 OSstatus20120821121325.txt
---------- 0 6801 Jun 4 11:58:52 2012 OSstatus20120824101325.txt
Can't get attributes of file 'OSstatus20120821121325.txt'.
File or folder 'OSstatus20120821121325.txt' does not exist.
Installation difference: just replaced .com and .exe from portable package.
Used .com variant for this session.
Log excerpt:
< 2012-08-24 12:27:09.495 227 Entering Passive Mode (140,15,45,121,117,70)
> 2012-08-24 12:27:09.495 MLSD
. 2012-08-24 12:27:09.495 Trying reuse main SSL session ID
. 2012-08-24 12:27:09.495 m_pSslLayer changed state from 0 to 4
. 2012-08-24 12:27:09.495 Session ID reused
< 2012-08-24 12:27:09.495 150 Connection accepted
. 2012-08-24 12:27:09.495 SSL connection established
. 2012-08-24 12:27:09.495 m_pSslLayer changed state from 4 to 5
. 2012-08-24 12:27:09.495 type=file;modify=20120604115852;size=6801; OSstatus20120821121325.txt
. 2012-08-24 12:27:09.495 type=file;modify=20120604115852;size=6801; OSstatus20120824101325.txt
< 2012-08-24 12:27:09.495 226 Transfer OK
. 2012-08-24 12:27:09.495 Directory listing successful
. 2012-08-24 12:27:09.495 Got reply 1 to the command 2
. 2012-08-24 12:27:09.495 ..;D;0;1899-12-30T02:00:00.000Z;"" [0];"" [0];---------;0
. 2012-08-24 12:27:09.495 OSstatus20120821121325.txt;-;6801;2012-06-04T08:58:52.000Z;"" [0];"" [0];---------;0
. 2012-08-24 12:27:09.495 OSstatus20120824101325.txt;-;6801;2012-06-04T08:58:52.000Z;"" [0];"" [0];---------;0
< 2012-08-24 12:27:09.495 Script: D--------- 0 0 ..
< 2012-08-24 12:27:09.495 Script: ---------- 0 6801 Jun 4 11:58:52 2012 OSstatus20120821121325.txt
< 2012-08-24 12:27:09.495 Script: ---------- 0 6801 Jun 4 11:58:52 2012 OSstatus20120824101325.txt
. 2012-08-24 12:27:09.495 Session upkeep
> 2012-08-24 12:27:21.182 Script: stat OSstatus20120821121325.txt
. 2012-08-24 12:27:21.182 Listing file "OSstatus20120821121325.txt".
. 2012-08-24 12:27:21.182 Retrieving file information...
> 2012-08-24 12:27:21.182 MLST OSstatus20120821121325.txt
< 2012-08-24 12:27:21.182 250-Listing /CBK/status/OSstatus20120821121325.txt
< 2012-08-24 12:27:21.182 type=file;size=6801;modify=20120604115852; /CBK/status/OSstatus20120821121325.txt
< 2012-08-24 12:27:21.182 250 End
. 2012-08-24 12:27:21.182 type=file;size=6801;modify=20120604115852; /CBK/status/OSstatus20120821121325.txt
. 2012-08-24 12:27:21.182 Retrieving file information successful
. 2012-08-24 12:27:21.182 Got reply 1 to the command 1024
. 2012-08-24 12:27:21.182 Script: Failed
. 2012-08-24 12:27:21.182 Session upkeep
http://winscp.net/tracker/show_bug.cgi?id=906
yaoops
Issue fixed in PM'd test version, resolved.
Thanks again!
