Topic "Connection to FTP over FTPS in Powershell via WinSCP.dll"
Mark Jenster
I've tried to find some documentation about setting up FTPS in powershell via the WinSCP.dll. As you might have guessed, it wasn't a succes. Same goes for a topic as this on the forum.
I know how to set the protocol to either Sftp, scp or FTP. The problem here is that I need to use SSL to connect, which I don't know how to set up. The connection fails everytime I try without it. The connection of course works when I use WinSCP directly, instead of Powershell.
Any help on this topic would be appreciated.
See SessionOptions.FtpSecure
Mark Jenster
Did it. Thanks. Now my problem is that I get a "Connection failed." message.
Nothing more. I might need to make a new topic on this though, if I can't seem to find it in the forum.
Works fine with WinSCP as standalone, but gives some troubles in in PowerShell.
This is fixed by setting in $sessionOptions.SslHostCertificateFingerprint = "[fingerprint]"
