Topic "tranfer of zip file fails via script however works fine with"
dgibson26
HI have a script which exports data then zip and then transfer via winscp however when i comes to transfer it fails, port 22 is open
any advice will be appreciated
Please attach a full log file showing the problem.
To generate log file, use /log=path_to_log_file command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
dgibson26
Hi managed to get this working
issue was script rather than winscp functionality
Script used was copied from 64bit machine into 32bit and where there is a ref to winscp program file to initiate transfer was "programfiles~2" when changed to "programfiles~1" all works.
Thanks again for response
