Topic "Error message "Failure""
gjs
I am using .Net component v5.1.3 with WinSCP 5.1.3, in a VB VS2010 project (though this issue dores not seem to be related to .NET component see last paragraph below). I am downloading files in a loop from a Linux Debian OpenSSH host with SFTP and get the following exception when executing session.GetFiles
"General failure (server should provide error description). Error code: 4 Error message from server: Failure Request code: 5"
Retries on the same file yield the same result. When I remove this file from the list of files to be downloaded the next newer file has the same problem.
I can use Filezilla Windows client to download all of the files without issue. Once I have used my program and WinSCP, and the failure has occurred, Filezilla can do the download but with the following errors in the log:
Status: Starting download of /mnt/usb/20130105.sto
Command: get "20130105.sto" "C:\My cache\20130105.sto"
Status: remote:/mnt/usb/20130105.sto => local:C:\My cache\20130105.sto
Error: error while reading: received a short buffer from FXP_READ, but not at EOF
Error: File transfer failed after transferring 1,024,000 bytes in 1 second
Command: reget "20130105.sto" "C:\My cache\20130105.sto"
Status: reget: restarting at file position 1155072
Error: File transfer failed after transferring 937,984 bytes in 1 second
Status: reget: restarting at file position 2129920
Error: File transfer failed after transferring 921,600 bytes in 1 second
Status: reget: restarting at file position 3198976
Error: File transfer failed after transferring 802,816 bytes in 1 second
Status: reget: restarting at file position 4198400
Status: File transfer successful, transferred 1,114,112 bytes in 1 second
Trying to copy the same files with WinSCP windows client yields the same error message as does using the .NET wrapper:
Error code: 4
Request code: 5
Can anyone suggest what is happening?
Thanks.
gjs
Please see session log attached. I cannot post the debug log as it is too big 1.3MB. Please let me know if you want me to email this.
Thanks.
SFTPSession.log (39.43 KB) [Download]
Description: (none)
Ok, please read this:
http://winscp.net/eng/docs/message_error_code_4
gjs
Thanks for your reply, Martin. Unfortunately, none of the suggestions in the linked article reflect what I am doing, this is simply a download (no writing to server) and I am logged in with root account so permissions should not be a problem.
I am sure this is something wrong on the server, but the point is that FileZilla is able to cope with it and complete the download (using "REGET"), so is there anything I can try with WinSCP to replicate the FileZilla behaviour?
Thanks.
"reget" is FTP command. You are using SFTP with WinSCP. Maybe that's the difference.
