Automation error SFTP task in SSIS.
limitha
I am getting the below error, while autonmated the SFTP task SSIS package.But same package running manually.Same pakcgae working properly differnt machines.
I have gave the full rights the folders. My enviroment as follows:
Windows 2008 R2 64-Bit
Sql Server 2012 64-Bit
Winscp 5.1.0 version
"C:\Program Files (x86)\WinSCP", The process exit code was "3" while the expected was "0".
Re: Automation error SFTP task in SSIS.
Are you running winscp.exe or winscp.com. If winscp.com, can you try to switch to winscp.exe?
limitha wrote:
Yes, earlier i have ran the winscp.com , now i was changed the winscp.exe.
Still i am getting the same error.
Please try to restart the machine with the problem.
limitha
After restrat the server it's working some days. After some days again we are facing the same problem.
Please help me...
Srini
Please help me...
