Topic "Windows Task Scheduler"
colemanr
Hi everyone I'm new WINSCP and from what I can tell I really enjoy using it. I'm having problems using the Windows Task Scheduler to Winscp and FTP a file over to a Unix server by automation. It seems like I can't get it over, but doing it manually. I'm thinking that its bombing on the Winscp commands part when it brings up another command line for Winscp, but I'm not completely sure. Any ideas?
I currently have Windows Task Scheduler openning up Winscp to a Saved session, but it doesn't or I can't figure out how to get it to copy a file over automated.
"C:\Program Files (x86)\WinSCP\WinSCP.exe"
"sadmin@198.68.33.43"
Arjun
create a winscp command script
eg
open MITTEAM@10.207.30.52 -------this has to be a saved session in your winscp
option batch continue
option transfer binary
synchronize local E:\Logs\ /Incoming ---------sync the "/Incoming" on 10.207.30.52 with E:\Logs,
close
you can call this script by a bat file and later can add the bat file to the windows scheduler to schedule
eg-
"C:\Program Files\WinSCP\winscp.com" /script="D:\Softy\LOGDOWNLOAD\pull.tar" /log="E:\Logs\Trace\pull_%dtStamp%.log"
here i'm logging the details using log="E:\Logs\Trace\pull_%dtStamp%.log, this is option if you dont need
cheers
Have you read these guides?
http://winscp.net/eng/docs/guide_automation
http://winscp.net/eng/docs/guide_schedule
If it does not help, please be more specific about the problems you are facing.
SarahY
I am a beginner and would like to use Windows Task Scheduler to automatically download files (e.g. pdf files) from one location (root/logs folder) to another (user/sarah/documents/log). I have read the 'Schedule File Transfer' guide and have tried using the following in the 'add arguments' box:
/command "option batch abort" "option confirm off" "open ftp://user:password@IPaddress" "get /root/Logs/*.pdf C:\Users\Sarah\Documents\Log\" "exit"
Could you please advise me where I went wrong? Thanks.
SarahY
All fixed, turns out it should have been "Logs/*..." instead of "/root/Logs/..." Smile
