Topic "Synchronized browsing problem"
Milos
I love synchronized browsing... Smile
The only problem is that it doesn't work if I change directory with Back and Forward history buttons... Sad
Would be great if it worked... Wink
Thanks a lot in advance for consideration...
If works for me even with the back/forwared buttons. Maybe it does not work only under some specific circumstances. Please tell me from what to what directory do you change with back/forward buttons. Any other specific circumstances?
Milos
Correction: it works with Back and Forward buttons... it doesn't work if I use the pull down "history" menus on those buttons (that means if I want to go Back or Forward more steps at once)...
OK, I can confirm that. I'll try to fix it. Thanks.
