overwrite remote files using session.putfiles
sferrand
There must be a setting for this, but I can't find it.
I'm getting:
Cannot overwrite remote file '/remotepath/myfilename'
Press 'Delete' to delete the file and create new one instead of overwriting it.
It looks like it's possible with scripting "confirm off", but how using the .NET component?
FWIW, I'm using a wildcard for the localPath
SteveF
Re: overwrite remote files using session.putfiles
This has nothing to do with "confirm off".
What is the reason WinSCP cannot overwrite the file?
Complete session log would be helpful.
After checking the log, I can confirm that your server rejects request to overwrite the file with "Permission denied".
