Topic "Delete remote files older than"
GTypeR
Hi. I've been trying to figure out if this is possible with WinSCP. However, I cant see if something like the -filemask switch is available for the rm command or if the synchronize command has a remote -delete switch, rather than a local one.
I'm basically trying to upload the latest file and then delete anything over 1 month old on the remote server.
I haven't got ssh access so I cant do it that way.
I've just thought, I may just delete the whole remote directory and just use a put command with the -filemask switch to upload the most recent files. I'll do this if there's no cleaner solution.
Use rm *<31D.
See
http://winscp.net/eng/docs/scriptcommand_rm
http://winscp.net/eng/docs/file_mask#size_time
schultkl
The 'M' constraint seems to currently refer to size, rather than time (that is, "M (Megabyte)") .
I see the following time constraints: "One of the following units must be used: Y (years), D (days), H (hours), N (minutes) or S (seconds)."
Might a month constraint exist? Thank you.
Note: we can get close enough for our purposes using 182D instead of 6M...
Thanks for spotting this. I have fixed my previous answer.
Isn't that enough?
