Topic "ls -la command fails on scp login with german LANG/LC_ALL"
Thomas Mack
When opening a new session with SCP and the remote login has LANG and LC_ALL set to de_DE.UTF-8 or similar, the directory listing via "ls -la" starts with something like:
aaaaa@xxxx ~ 176 > ls -la| head
insgesamt 3122724
drwxr-xr-x 165 mack users       32768 Mai 18 23:01 .
drwxr-xr-x   3 root root            0 Mai 19 15:30 ..
-rw-r--r--   1 mack users      270013 Feb 25  2011 104510.pbm
The first line is "total 3122724" in english environments, which works ok.
WinSCP tries to interpret the first line ("insgesamt 3122724") as a normal output line of ls -l and stumbles over the file permissions "nsgesamt" resulting in a missing directory listing.
The german error message reads:
Fehler
Fehler beim Anzeigen des Verzeichnisses "/".
Unerwartete Zeile in Verzeichnisliste "insgesamt 27156".
Ungltige Rechte Beschreibung 'nsgesamt '
OK   Hilfe
Error
Error listing directory "/"
Unexpected line in directory listing "insgesamt 27156".
Invalid permission 'nsgesamt '
Ok Help
WinSCP unsets both these on startup. Unless you have disabled this functionality (Clear national variables):
http://winscp.net/eng/docs/ui_login_scp
