WINSCP and .Net Assemblies
TheDM
Fort Waynem IN
Hello! My company has made WINSCP available for use to use. I am working on a project that needs to transfer files to our SFTP site. But there is logic involved in performing the transfers. The machine creating the data files we want to send to our sftp site uses two files. First it creates a .csv file and appends to it as needed. When the machine is finished, it creates a .end file of the same name. So what I would want the program to do is to create a file list of the .END file names and move the files Replace(filename,".END",".CSV") to the sftp site. I saw you can use .Net assemblies. Is it possile to do this within the assembly? or can it only use code from the WINSCP API? Can I use any VB code I want in the assembly :?:
TheDM
Re: WINSCP and .Net Assemblies
You can write your VB code to collect list of .end files, replaces the .end with .csv and then call the WinSCP .NET assembly to upload these.
