Topic "5.2.2 beta error when running."
JeffClay
Quote:
The version of C:\Program Files (x86)\WinSCP\winscp.exe (5.1.5.0) does not match version of this assembly C:\Users\jeff.clay\Documents\Visual Studio 2010\Projects\VOIP-no-service\VOIP\bin\Release\WinSCPnet.DLL (5.2.2.0). You can disable this check using Session.DisableVersionCheck (not recommended).
This is the error when trying to use the 5.2.2 beta version. Just an FYI.
That's correct. You need to use the same version of the assembly as WinSCP.
