Topic "How to delete files after copying"
bkand
I have the following code to copy files from the remotes server onto my local server. Can someone please help me or advice me as how to delete the files on the remote server once i copy them?
option batch on
open sftp://<username>:<password>@server -hostkey="ssh-dss xxxxxxxxxxxxxxxx"
cd .
option transfer binary
get -preservetime *.txt F:\FTPShare\ftp\
 close
Please need help.
Use -delete switch of get command:
http://winscp.net/eng/docs/scriptcommand_get
For alternative see:
http://winscp.net/eng/docs/faq_delete_synchronized_files
sgarciav
I noticed that in the example the GET statement uses a wildcard. Is this allowed with GET in general or is this a WinSCP specific feature? Thanks, Salvador
What is "GET in general"?
sgarcia
"GET in general" - What I am asking is whether the use of wildcards is a standard feature of the GET command or whether it is specific to WinSCP. Thanks, Salvador
The get command is a specific command of WinSCP. If you are using a different tool, that also has a get command, you should seek a help with their support. There is no global specification of "get" commands, as far as I know.
