Topic "Remote on both sides"
It would be useful to be able to have remote servers on both sides. Then you could copy from one server to another.
I have read the FAQ on this at but it misses the idea. WinSCP would act as a "middleman" in this case, loading the file from the source remote server into memory, and feeding it to the target remote server. You could even do this at the same time potentially.
Yes there are all sorts of network caveats associated with this but it's still feasible.
For comparison, the command line SCP command does support remote servers for both source and target arguments. For example:
is totally legitimate and will work. The scp process on local serves as a conduit between the two remote servers. WinSCP should be able to do the same.
While WinSCP cannot have remote side on both panels, you can still connect to several servers at the same time and transfer files in between them.
